majornelson said:
I am building a light speed, cruiser for short runs around home and to work. It will be powered by 5ah 48v lipo. I purchased both the Cute Q100 201 rpm and a 36V250W Bafang SWXK5. Both are front wheel mounts.
Goals are:
- assist up a few modest hills and speeds up 18 - 20 mph, with assist is fine.
- stealthy look with little noise
I've read a lot of back and forth on the forums. Thought I wanted to install the Cute and now thinking it' the Bafang
I'm collaborating with
footloose, another member, to compare the Q-100 with the Bafang SWXU. I also recently built an SWXK into a 700c wheel for my wifes bike. Since we are doing a comparison we examined, weighed, no-load speed tested and listened to all these motors. So far we have built the SWXU into a 20" and ridden it. We have not yet built up the Q-100. I've also ridden the SWXK in the 700c bike.
The measurements are:
[pre]motor code wt KV notes
SWXK 201 2.9kg 6.5 0.54 mph/V@700c
SWXU 201 2.3kg 6.49 0.53 mph/V@700c (0.39 mph/V@20")
Q100 201 2.3kg 6.23 0.51 mph/V@700c (0.38 mph/V@20")[/pre]
Subjectively, with the same controller and battery in my test rig I can grab and stop the SWXU and Q100. This is impossible with the SWXK. They all make about the same amount of noise at no load full speed, but they sound different from each other. On the road, the SWXU is louder than the SWXK especially when just cruising at part throttle.
I like the design and construction of the Bafang motors better. No cable through the axle for one, it just looks more thought out. The internal gears on the SWXK are much larger than on the Q100 or SWXU.
On the road with 12s lipo the SWXK in 700c goes 23+ mph. At 14 amps it is pretty good, but at 21 amps it is more than strong enough for fairly steep hills for my wife, or even with me. I'm heavy, 270lbs, but pedal hard on hills and can climb a few blocks of 12% grade with the SWXK although I don't think it would be happy on a long grade like that. The SWXU would not do this at all, and even in a 20" wheel it bogs down on grades a lot more than the SWXK. Of course some of that is the the extra amps for the SWXK, but that's the thing, the SWXK can handle it and the SWXU almost certainly cannot. It gets a bit warm at 14 amps on hills that leave the SWXK cool on 21 amps.
I picked the SWXU for my 20" folder that I have to carry on stairs and wanted to minimize the weight. It's ok, I'm not unhappy with it, but If I had to do it over I would choose the SWXK/SWXK5 over the smaller motors. it is only 0.6 kg heavier but it is much more capable. I'm really pleased with it. The SWXU is ok in a 20" wheel, but there is no way I could use it in a large wheel, it would just be too wimpy.
I assume since the Q100 is the same size and mass as the SWXU that it would that it will perform similarly.
