Atak_Snajpera
- Joined
- Jul 21, 2022
- Messages
- 301
yep. fasterbikes.eu also have them in stock. Unfortunately price went up from 950 euro to over 1000 euro (motor only!)
I think i will wait for the next gen of the Photon, hopefully with a biger motor that can do power levels like the BBSHD... the good torque sensing PAS sounds nice, but i also want >1500 W of power and not only for a short moment but permanent without overheating the motor.
true...That would be nice, but a motor capable of that will need to be a big ~13 pound lump like the BBSHD. Current Photon is a good compromise of power, weight and efficiency for bike pedalers. I'd like to have one bike with a BBSHD with torque sense. But that's not ever gonna happen.
jop, i do that all the time but also only within a certain limit.So what I hear is that you want to lay waste to your bike's gears expensively and often. Is that it?
your right, therefore i think its important to to have a stable bike with quality parts as a basis.Remember the motor is only one part of the system. You can overpower it as much as you like, but it won't increase the capabilities of your bike's transmission or remove its limitations.
Cassettes and chains are pretty cheap the last time I checked… gotta pay to play and it’s a very small cost every few hundred miles which takes most of us a long time to reach.So what I hear is that you want to lay waste to your bike's gears expensively and often. Is that it?
That depends on what components you use. A Microshift Acolyte 8 cassette runs about $30. Shimano XTR cassette is about $400. Neither one will last very long if you feed it 2hp regularly.Cassettes and chains are pretty cheap the last time I checked… gotta pay to play and it’s a very small cost every few hundred miles which takes most of us a long time to reach.
I think you're exaggerating a bit there... The cassette on my Marlin 8 is a SRAM PG-1210 Eagle 11-50T, 12 speed. They are around $50-$100 which isn't a big deal every year or two if you even put that many miles on it. It's considered routine maintenance when you run a motor like the Photon in unrestricted mode. BUT, if you let off the throttle when shifting like you're supposed to, it's a non issue and not much more wear than a standard bike if you have proper chain tension and gear selection.That depends on what components you use. A Microshift Acolyte 8 cassette runs about $30. Shimano XTR cassette is about $400. Neither one will last very long if you feed it 2hp regularly.
As for the Shimano XTR Cassette, why the hell would you run one of those anyway?
chinese ltwoo a5 with 50t is cheap as dirt and works quite well . I have twoThat depends on what components you use. A Microshift Acolyte 8 cassette runs about $30. Shimano XTR cassette is about $400. Neither one will last very long if you feed it 2hp regularly.
Can anyone make recommendations for shorter cranks for the Photon? My left one has come loose 2x and I'm wanting to try shorter cranks anyway.
Would be good at that price but those are Cotterless/Square and Photon is ISIS.United Black Cotterless Cranks -150mm
United cotterless crank arms for distance riders. 102-mm, 8-inch, 12-inch. 110-mm & 127-mm, 20-inch wheel. Req. crank puller tool from dropdown menu.www.unicycle.com
I use the shimano 8 speed hg400 11-40 They are about $30 and chains are dirt cheap too so I have a spare set ready to swap as soon as it gives any trouble.. 1400 miles so far.
Sure are. There's sometimes good reasons to consider shorter cranks, especially on ebikes and for shorter and older people, or where you might want to sustain a higher cadence (again - ebikes). Probably worth considering by people with knee or hip problems, too.150? Thems some short cranks.
Disagree. Most people don't even know they exist.Dropper posts arent required for the majority of the riders
Agree, I had really tighten mine just to stop the sloppy 34t chainring from rattling around.CYC told me not to overtighten the retaining ring.
But after 300km a slight clicking noise appeared.
I tightened the retaining ring and the noise disappeared.
It is difficult to ensure that the recommended force of 40 to 50 Nm is accurate.
