stypherfire
1 W
Hello Endless-Sphere Pepe's,
So i just took another rather nasty tumble today on my Bike after some guy cut me off and then a cone & construction duo decided to cartwheel me down a street. A few bumps and bruises but all in all i am okay. The bike took a hit though. The problem currently is the following:
The build:
Mac 500W Motor Rear Kit
Trek 26" MTB
6T @ 390 RPMS winding
9 fet 30A Controller
DNP 11T 7 speed free-wheel
Battery
Turnigy 5000mAh 6S1P 22.2v 20C pack x 4
Complete Hobby King Lipo Protection Kit fro Methtek
Throttle
thumb type (separate 3 speed switch)
Others
GRIN Universal Rear Torque Arm, thick 1/4 inch stainless steel.
Cycle Analyst 2.3 CA-LDS
The Problem:
Cycle Analyst currently looks roughed up (shell casing still intact, no cracks) and the rubber selection pad fell off (still have it, going to epox it back on). When i switch on the bike, the CA back light turns on and nothing. At this point, i can throttle and it moves a bit (slower then normal). If i wait a bit or hit a button, i get a line of black squares and then "Cycle Analyst 2.3" something or another (what normally last only a few seconds) and stays there.
So now for observations. The rear rack which the controller was sitting on is bent at a painfully weird angle. This is obviously not a good thing however after looking over the exterior and wiring coming from the controller, i would say everything is good ( the entire thing is shrouded in thick foam normally). Battery is Good since it is also protected with double layer of corrugated sheets of plastic on either side and top and bottom with foam (triangle bag). The controls on off switch seems good however the throttle is shattered at the switch that lets you change speeds/cruise. The twist throttle part seems fine. The shattered part, after close inspection looks like the connections are still connected and should be working. Breaks are good and hub wires looks fine.
I am 90% sure it has something to do with CA crash emergency shut off (looked around) however can't get it back out of the stuck area. Any help?
The build:
Trek 26" MTB
Battery
Throttle
Others
The Problem:
