So I had a shop install a cycle analyst, Infineon controller, and cycle analyst on my bike after the original controller died (another long story which resulted in the shop also installing some torque arms). The bike is a custom setup with a 48V LI battery and 8FUN motor, and otherwise what appear to be generic parts.
When they gave it to me, all was working (although the pedal assist was lurching since it wasn't dialed in quite right), and then after one or two rides both the pedal assist and the cycle luminator both stopped working. Thankfully the twist throttle still works (and the auto cruise function is great).
To start simple, I decided to troubleshoot the cycle luminator first. The cycle luminator is hooked up to what appears to be the power output of the cycle analyst. The odd thing is that when I'm riding down bumpy hills, the light flickers on every once in a while. I followed the wiring harness back to the cycle analyst, and found that it wasn't generating any voltage from the power output. I opened up the cycle analyst and traced the wires back to where they hook up to the board, and there is no voltage even right where the wires attach to the board:
Any thoughts/tips on how to troubleshoot? Is this a fault with the cycle analyst, did I accidentally turn off the mainboard, or is it possible something somewhere along the line is shorting?
