brickwall
I think I solved it. Turns out my shunt value was set to 0.1 mOhm when changing to high range mode. setting it back to 0.92 removed my problem. You learn something everyday.
madnut said:I have a Phase Runner paired with a CA3. But the two seem to slightly disagree on Wattage being used. Controller says I am at 3000W but CA3 says it is around 2750W. It seems to be a difference in Amperage measured. Which one do I trust more? I am assuming I need to Calibrate the CA3.
speedmd said:Getting ready to connect my first CA (v3) with a new sunwin controller on the old c-dale and I am both a bit excited and frustrated with all the details that I am not sure of. Been doing most of it near bed time (reading up, wiring etc) which is not my best time of day, but all that is available this time of year for me. Somewhat concerned it is this complex, or my years are starting to show the added difficulties of taking on new challenges and not being confident I am not missing something important. Not sure on all the throttle and 3 speed switch connection and setup details, but certain I can figure that out, but just need to keep taking baby steps. Wheel speed pickup wired to CA board up is next. Is there simple step by step outline one can follow as a check list. Just looking for some hand holding I guess.
ebike11 said:@ Justin..
I was wondering, if i reach the LVC of the Infineon controller or CA3 LVC, will the CA3 screen shut off?
The reason I ask is because as I was riding and as my voltage got close to 30V which is the LVC of the controller and also the LVC that I set on the CA3, I noticed the screen flicker and power off then power back on again. I want to know if its normal or a wire/connector problem.
speedmd said:Got the V3DP working with the rewired sunwin with the throttle going to the ca. The throttles 3sp switch is disconnected. I am not finding the ca in the setup upload with the wife's mac. Tried the serial port utility posted on pg 140 with no luck. I will drag the bike into the office and try programing it with the windows machine next if I can not get better results in the AM.
Can not get the bicycle wheel speedo pickups to work either.
teklektik said:brickwall said:I get cutouts when I set the bike to unlimited (99 kW) and accelerate hard.
Later 3.1 beta firmware correctly set the 'S' limit flag even for this acceleration-based speed limiting situation.
brickwall said:teklektik said:brickwall said:I get cutouts when I set the bike to unlimited (99 kW) and accelerate hard.
I did disable the speed limiting logic before I posted and got the same results. Using Power Throttle now. Maybe it's a PGain issue (too high). Will try that lowering that too.
brickwall said:However, I might have found a clue. After some testing I noticed this issue is temperature related. It does not occur when the bike is cold, but only after heavy use. I suspect the cutouts have to do with the controller shutting off due to throttle overvoltage, which for some reason happens sooner when the controller is hot. I lowered max throttle output to 3.35V (from 3.55) and it no longer occurs. Need to do a lot more testing to verify this was the cause and that I still get max power output, but it seems plausible given that I had some issues with motor creep due to min throttle voltage being set too low (when hot).
Marc S. said:Problem is, since the FW update PAS level doesn't go down to 0W if I 'close' the pot. At the '0W' setting of the pot the display shows arbitrary numbers from say 23W to 48W, sometimes close to 100W. Very seldomly it goes to 0W.
The 100% PAS level (400W) always works.
Is it possible to only display the cell voltage in the main screen?
The cops get fairly suspicious if they see '81V' battery voltage. If the main screen only displays a '4.05V' cell voltage, its much easier to stay under the radar (last time I got a €400 fine...).
First thing to do is get the thresholds set up for the pot. It looks like your LoDeadband is too small (although there may be another issue in play as well). Increase it a small bit, then go to the AUXA category Preview screen, turn the pot to minimum and slowly rotate/increase it a tiny bit. Keep increasing LoDeadband until you get a good solid zero reading on the preview screen at the minimum pot setting and for a few degrees of rotation.Marc S. said:I've got a pot at AuxA, it controls PAS level (didn't change the threshold levels).
justin_le said:Hey Marc, can you tell us what you have for your actual min and max aux input values and what voltage you see on the aux preview screen as you rotate the potentiometer all the way from min to max? That should hopefully tell exactly what is going on. And I'm presuming that you only have an analog potentiometer hooked in, there is no digi-aux buttons in the circuit as well?
justin_le said:This was the subject of much debate between me and Teklektik! Initially the implementation only showed the cell voltage on the screen, rather than toggling, but I found it quite ungrounding to not also be aware of the full pack voltage while riding, so we opted for the alternating CellV / PackV display choice here. This could be a bit of me just being so conditioned from years of riding with pack voltage on display that I'm always thinking in that frame of mind, ie I know I've got maybe 10km left when my 14s packs is at 50.0V open circuit, and that with time that would be relearned in terms of average cell voltage. In any case it's not out of question to have a choice between pack volts, toggling pack/cell volts, or only cell volts, and I'd be interested in more feedback from other users on this point too,
justin_le said:Yikes! Was the voltage read out on the CA part of the giveaway here or were you clocked going at rather superhuman velocities?
Okay - setting sounds fine now so that business is off the table... The granularity of change seems odd - this will need some thought and tinkering.Marc S. said:I've raised the lowDeadband threshold level and it works... better.
Still nowhere near as smooth and precise as in v3.1b10 (while in the setup menu, its all nice and smooth, even with a LowDeadband setting of 0.15V).
While turning the pod, the display still seems a bit sluggish at changing the values. Sometimes, when turning the pod end to end, it goes from 0-max without 'counting up' (or down). It still doesn't go down to 0W every time, though.
Yep - that AuxChange pop-up was pretty annoying. We now have a new upgraded pop-up that shows the actual delivered power at the present rpm. This seems a big improvement over the previous 'baseline power only' display that omitted the rpm component.Marc S. said:I definately want the 0-100% assist power display back!
My assist power factor is set to 8W/rpm, my cadence is between 85-100rpm and I've got a Patterson Metropolis with 1:1.6 overdrive. The actual max assit power is around 1.1kW when I'm pedaling in overdrive.
Hence the PAS power I set with the pod, has nothing to do with the actual PAS power. The 0-100% display was much more intuitive.
