danjpendleton
hey everyone,
Just took my bike to work and back for the first time and loved every second of it. I set up my cycle analyst the other night though and have a few questions.
I reset my trip at work after charging and then rode 14 miles home and took a few pics of the ca.
The accumulated battery Ah in the right hand corner is 16? what does this mean exactly?
Heres a pic of the total trip distance and battery voltage after the ride. My low voltage cutoff is programmed for 64v in the cycle analyst and after speaking with paul from em3ev he agrees on that. the battery bms will prevent the battery from being damaged regardless.
Alright so heres it shows 1257 Watt hrs which i assume is total usage for my 14 mile ride....which confuses me because my battery at 90% charge is 86 volts. Its a 13.3Ah battery. So my calculated capacity in watt/hrs should be around 1143 right if u multiply 86x13.3?
I dont really understand how those numbers add up?
This pic shows no regen % but i have ebrakes hooked up and it shows the brake levers being actuated on the cycle analyst when you squeeze either lever? do i have to enable them or something?
Heres a pic of forward Ah. can someone explain this to me?
FAST
Amperage max and voltage min
And lastly calculated internal resistance of the battery
Id like to figure out the ebrake thing and also how much battery i actually have left. Theres a meter to the left hand corner but there has to be a more precise way of knowing how much juice you have left.
FAST
