thomas
Juss a few basic questions about the HC model...
I got a 50mV/600A shunt this mean its 0,0833mOhm right?
With this shunt the CA must be set to high range mode right?
I did alittle test run but with the default setting wich was 0,5mOhm and I was getting wierd readings. I guess this will change when the shunt is set to 0,0833mOhm in the CA.
Do you know what the max clearance between the magnet on the wheel and the pickup is? I got about 9mm and it seems to be reading the speeds just fine but could the big clearance affect the precision?
