Dave's 80:1 RC mid drive kit build log
There's the new version of the 40:1 transmission that should be a bit quieter. I have it in my possession but I haven't had time to complete the build. Once I do, I will record some video/sound samples.
Oh cool! Can't wait to see it!
the sound comes from the gearbox. you can't get rid of it. if you want silence you need gearless motors :)
some like the noise - which reminds me of a small 2-stroke ice, but i prefer super silent electric motion - for the moment. this can change anytime ..
If this setup could be silent, it would be the best drive for almost any ebike application in my opinion.
Now I am usung direct drive middrives or dd hubs to keep the noiselevel down, which to me has become one of the most appealing points with ebiking.
Regardless, this drive is an engineering masterpiece in my book and I love to follow the progress.
Yes, I went the polar opposite of the ebike and got a motoped, and it is really fun but VERY limited as to where you can ride. Most see it as a motorcycle and get very upset if you are on their trails! I'm selling it now to get a nice middrive fatbike, I think that is the epidomy of single track ebike machinery! I want to go full out with a carbon fattie around 25lbs, then add a light drive like this or the BBSHD if I have to and enough battery to go for a couple hours at least into the goat trails out here, its beautiful terrain but very steep and rocky so you need huge torque and fat tires for comfort :)
It's a "Goat-Worthy" build..
Awesome! Do you have a link to the build?
That's precisely why I went for it. I was going to buy a BBS02, but then when I compared the two - 750W in 4.2kg vs 2000W in 3kg... Even if you only want 750W, or even less - set the power limit in the Cycle Analyst and it's still worth it for the weight and durability.
Hi,
I just want to ask. Which rear hubs you guys use? I have pathetic 500W bosch middrive and i just cannot find hub /142x12/ which can hold torque. I keep stripping pawls in freehub. /third this season/ I have 42t sprocket on rear - so torque is proportionally larger and im heavy but even so... Which freehub can hold 2000w?
many thanks
Tomas
My hope pro 4 has been holding up good so far at 5000w
Same here. Hope Pro II, Chris King, Rohloff all hold the power fine. The cheap, stock Shimano freehub on my road bike failed almost immediately but the replacement held up fine.
Another Hope user here (Pro II Evo) - no issues to date.
Also there's lots of talk about the noise of gearbox, but I think most people move out of my way on sidewalks and stuff because of the 'clack, clack, clack' of the hub as slow down :).
Thank you guys.
Just FYI
Stay away from Novatec, Sun Ringle and shimano. Novatec - broken pawls, Sunringle - main axle keep breaking /i broke 3 of them/ /freehub body literally stripped of hub - pawls and pawl race skipping/ Shimano bearing are terrible and non reparable - all in 142x12
[youtube]PZiIVeFnI6k[/youtube]
This is Eric Olson having fun on the pump track after Sea Otter. He's on a Banshee Phantom 29er running a 3210 kit with a Rohloff Speedhub in the back.
-dave
Hi do you think you'll ever sell this system? I'll definitely take one straight away. Fantastic job
So here's someone passing by on The Chainsaw. This is the new, lower-noise transmission Dave posted about a week or so back. The system is running from lower mid to high RPM so this is about as noisy as it gets. Personally, I think it's the sound is perfectly acceptable. I don't know why it wouldn't embed the YouTube video but here it is:
https://www.youtube.com/watch?v=kDdd1B8Vavk
Note that the system shown on the video accelerates slowly because it's severely limited to the Canadian legal limit of 500W/32kph and throttle ramps are set to very low values.
The lack of noise is such a plus with this and the fact that it is visually so subtle...each person that has seen the bike just assumed it was a normal bike when i showed mine.
The sound is great for gear changes too and if i happen to pass people i just back off the throttle and coast, down shift and off i go again.
More testing today now I've a new cassette and chain.
Dave
I am confused the Castle Creations Phoenix Edge HV 80 Specs input voltage is MIN: 3S LiPo | MAX: 12S LiPo
you say Battery Requirements: 50V max (12S LiPo or 14s Li-ion recommended)
12s is 38.4 to 50.4v
13s is 42.0 to 54.6v
14s is 45.2 to 58.8v this 14s way beyond the MAX 12s rating of the HV80.
14s works great on the Castle HV controllers. Full charge on 14s reads about 57.5V and in practice most of the time the system voltage is 50-52V, so...perfect :)
The Castle Creations stuff is quality. We're not using as intended, but we're not too far off either. The constantly varying motor RPM due to the reduction and mid drive setup keep the controller from being stressed very often.
-dave
Thanks Dave
OK what you a saying is that Castle Creations HV line is underrated and is the typical 63V Max capacitors
I see that Astro can add a Temperature Sensor 32xx for $15 can you make it work with the CA V3?
