http://endless-sphere.com/forums/viewtopic.php?f=2&t=66455&p=999943#p999726
Sorry, wasn't meant to mislead, just that most of the breakers people seem to end up using or wanting to use are not designed as switches (or rather, not ones for frequent/repetitive switching like will be done on many bikes, potentially multiple cycles a day).
The other issue is that brought up by others above, that the initial current thru the breaker is likely to be very high for the first instant, because of the discharged caps in the controller. I'm not sure what kind of initial load these breakers would normally see in solar or marine use, when used as switches. It might be the same, and if so, they're probably designed for that. IF not, they may not be, and then contact wear could be higher than normal.
I use a DC-rated breaker on CrazyBike2, and it gets switch cycled a minimum of twice a day (on, off, on, off), and sometimes 3 times if I turn it off when I get home and then back on again later to charge, instead of charging immediately (if I get home before 9pm in "winter peak power hours" then I wait till after that, as peak power hours cost more, I forget the time for summer hours).
Even more cycles per day when I make side trips. Weekly, on average, I probably cycle the switch 20 times. 52 weeks in a year gives me 1040 cycles, so lets' call it 1000 cycles a year. I think I've had the breaker on the bike since 2009 or 2010, so let's say there's 5000 cycles on it now.
No issues so far with it, and I know there is a pretty massive spark in there, as I have forgotten to turn it off when hooking the battery back up after maintenance/etc., and it's quite a pop with the caps of two controllers and a DC-DC to charge up (enough to scare the dogs out of the room and light it up if it's dark).
