I built this bike up from a frame last year and thought I finally had the bugs out.
BMC V3 Hub 48V 1000 W Used
Lyen Controller
CA 3
twist throttle
3 speed switch
I just pulled this bike out for the new season, it charged to 54V ( full for my battery) and started up once I reconnected everything.
At the end of last season I was just figuring out the CA but seemed to have it running smooth and also with in the pedal speeds that suited the three settings.
I had a good twenty rides in no issues except for configuring CA with three setting switch.
1) set for starting and town, if I pedaled more then 10 mph the motor cuts out.
2) set for Bike Path 20 mph
3) 30 mph... I am late picking up kids.
I have quite a bit of experience building bikes , limited electrical experience, no ebike experience.
On the first ride into town this season the motor cut out mid ride
I checked my connections and they seem fine, also checked battery charge fine
There is no motor noise/function in any speed setting or any throttle position.
The hub moves fine by hand and still pedals fine
I have contacted Edward Lyen and he is a great help but need to learn more about how these entire systems work.
We are working on diagnosing the problem.
What I have checked
With My fluke I have 54 V to controller
While plugged in I have 11.88 V DC coming off my main Blue, Yellow, and Green larger Gauge wires running to the hub. ( PLease explain this to me) This does not change when I change the 3 speed setting , this does not change when I have the throttle full or off .
Testing the smaller wires running from the hub to controller ( Hall sensor) ... All from the controller side...... everything plugged in ....
I have 4.29 V from red to black
from black to blue and turning the wheel slowly in reverse I read 5V to .034 V to 0 V back to 5V
from black to green I read 5V to .034 V to 0V back to 5V
from black to yellow I read 4.81V NOT 5V then .034 V to 0 V then back to 4.81V
also if it matters I have continuity between all phase wires blue,yellow, and green. I have NO continuity between phase and hall wires lg blue to sm blue, lg yellow to sm yellow, lg green to sm green . I have never seen a hub open so not sure what that means .
Any tips?
Also I would love to understand how electrical bike systems run from the ground up, so I'll be better equipped to diagnose problems understanding what electricity/voltage/watts/amps all mean and how they relate to the system and how the systems components relate to each other. Any suggested readings????
Appreciate your time
Donny
Lyen Controller
CA 3
twist throttle
3 speed switch
What I have checked
Any tips?
Donny
