Do headway cells really need a BMS? I'm thinking no.
Here's why:
1. EXPERIENCE: I've used thundersky 100 ah batteries (which is LiFePo like the Headway) in my car for the past year without a bms and I haven't had a problem yet. Actually, i did replace one cell that was killed by a shunt resistor type bms and that's when i took out the bms.
2. LiFePo CHEMISTRY: the Lifepo chemistry is good at masking their true condition. When at rest, they're all just about the same voltage +/- 0.02 volts. The only way to tell if a cell has a problem is install a cell log or similar data collection device and see how it performs under load.
3. WEAK CELLS STILL WORK: even if you do have a weak cell, it will still operate-- you just don't have full pack voltage under load since weak cells sag. Check out this battery test here http://s2kev.blogspot.com/
4. WHEN CELLS DIE, THEY BECOME A SHORT: The one cell that died on my car became a short circuit. I was never stuck-- though i was freaking out over the lower pack voltage. I replaced the dead cell with a brand new one and it integrated itself nicely into my pack without any fuss.
So, I'm asking people out there that have had experience with LiFePo4, if you are using a BMS, is it a worth while thing to have? WHY? I understand that some cells like early ping batteries and other 2C rated Lifepo batteries might have issues that a BMS may be useful for but for a 5C continuous (15C burst) cell like the Headway, how does having a BMS help?
- jon
Here's why:
- jon
