thanks for the reply lantice13,
But this issue should also be present with the middrive only bikes since they are putting a lot more force on those threads
they aren't using thread on freewheels with rear sprockets are they? Aren't they usually modern free hubs with splines as found on bicycles these days?
I think this setup would work better if both motors are close enough to each others peak watts rating so that they can share the load more evenly. The middrive could be a little weaker since you have the bike gear advantage. the 750w motor will only be capable of taking away 750w from the other motor 1:1. It's really a balancing act finding the sweet spot for both motors in a hill climb.
Personally with my limited knowledge, I believe that the hub since you have one will be much more reliable to take 5000 watts peak than anything running through a drive train, and do that with less heat as mine is vented. There's no way I can carry that much more battery to run the second motor even near that watt peak.
The mid drive second motor I hope will be almost totally used in granny gear. I am just doing rough guesses that 5000watts @ 10 kmh on a hub = 1000 watts @ 10 kmh in granny gear mid drive.
As for testing properly, its just a pain. To be done properly, I need to record tests
1, with the bike as is
2. with only the mid
3 with both
and then probably trial 12s2p hub vs 12s2p mid.
making sure only to use the same number of cells.
Looks like we've got a week of rain ahead of us, was waiting for all parts but since I cant ride my bike anyway, I am going to start building tomorrow, but unfortunately I am waiting on batteries and adaptors and then the holidays means this will probably not be complete till January...
Not my kind of holiday....
