Some material arrive. One chain, I bought from e-bay...take 75days to arrive. From the U.S.A. to Europe. Can you belive ? Now, I have 2...diferent color.
Finnaly, I finnish the atach points, for the side panels. It was a lot of work, and very precise.
I already have the side panels cut 80%. Its fine tunning.
I can see the finish line....far way...but I can see... :wink:
Its time to finish the side plates. Its going to be 1.5mm alluminium. They are cut to 80%. Today I find the location off the srews...I use acrylic , and then transfer the location off the screws to the alluminium.
After they are atached I tune to 100%.
In the first picture, it already have the acrylic atached. Its hard to see.
SlowCo, thanks men. Glad you like.
the12be, as always, thanks. And thanks for pay attention.
kachou, welcome. The battery box, is 28cm long x 23cm hight x 30cm on diagonal. And 15cm widht. And the frame, I fund just one size.
Wolfeman, the battery box, looks big, but its not. The frame is a S. Small. It will be 100volts 10amps off lipo. 24s 1p. In the future, I will use 18650.
skeetab5780, its 2cm more wide, than necessary...but thats the material I could find was 15cm wide, and I need 13cm. Thats ok, 2cm for foam.
