jerome_speedy
I definitely want two batteries to be used at the same time: first of all, with two batteries in parallel, the intensity will be divided by about two (when both batteries voltages are identical).
Secondly, I need the hub battery to be active, otherwise the TF controler goes to sleep after 10 mins (or so i've heard).
Thirdly, without the hub battery, the original controler is useless. In my configuration, I hope it'll be able to continue showing the remaining charge.
As for mixing voltage, the MBR3060 double rectifier should take care of any potential damage.
