Rodney64
Yes tuff as. Will give it ago before spending another $200 on another rim and tyre for the front.pendragon8000 said:looks tuff as!
front wheel being bigger helps handling I beleive...
Hey Fred,
we watched your homepage and noticed your interesting vehicle. Attached you find a picture of our prototype “PenBike”.
Maybe our Advanced Belt Drive could find your interest.
To answer your question about width of bottom bracket 120mm:
There is a housing 50mm longer as standard BSA 68mm leading to 118mm and 4mm longer nut implies 120mm
These special version is named “Flyke”
Best regards,
Rolf
Thank you Rolph!!
Ignore previous email, for a second I thought I dreamt it, it wasn't coming up in trash section either, finally did excuse me .
Very beautiful bicycle, looks like electrical hub in rear may I ask what speeds it reaches?
Let me give you an idea of my setup so you can better advice me.
I will be using high tork hub motor "cromotor" on phasor frame with 100v, probobally use 19 motorcycle rim and tire giving me an approximate 25" bicycle tire diameter.
http://endless-sphere.com/forums/viewtopic.php?f=31&t=46551
I should be able to reach speeds close to 80kmh.
This is the setup I was thinking of.
Speed drive with 2 chain rings. Outer ring (primarily used) 48t and 30t on inside to manually switch in case I broke down.
Rear 14t single freewheel with chain tensioner. I've also looked into the possibility of maybe using white dos freewheel 16t 18t(depending on dropout room)just a bit more flexibility if needed
with 160mm cranks.
http://www.whiteind.com/singlespeedgearing/freewheels.html
This should allow me to pedal on 48t up to 40-45kmh and after changing gears 79t which should allow me to pedal close to my top speed.
Belt drive seems very tempting, though I don't know what kind of flexibility it will allow me.
What do you think? Any suggestions, advice much appreciated.
Thank you
Fred Einhorn
Rodney64 said:Yes tuff as. Will give it ago before spending another $200 on another rim and tyre for the front.pendragon8000 said:looks tuff as!
dimpirate said:Been working to much last week so haven't had time to post.
Korpin I hope you've figured out your battery situation, if not do so quickly, I've had a whole pack die on me cause controller got left on when I was traveling, it's a real bummer and lots of money! So if your dropping 6V every couple of days it isn't long before your pack will be completely drained or under 2.9V and make it unusable, or even worse dangerous!
With regards to Schlumpf I've been directly in touch with them thru emails. They very well may have a solution for 120mm dropout width on phasor! Should get a reply by tommorrow. They are also going to send me a quote for 20 high speed/speed drive. Should come with %20 discount.
Don't know if I'm inclined to man group buy myself. I travel for work, so even though at the moment I'm home, at any given date I might be gone for three months...
Also I am a pretty new member, so no reason why anyone should trust me with there money. After I get quote (so I can give all exact price) ill open new thread see how many people are actually interested, and we can go from there.
For us phasor users that want Schlumpf if they offer a solution for us, I'll purchase one whether or not group buy goes thru.
Be nice if we could make it cheaper though.
Any Schlumpf info you might want here
http://www.schlumpf.ch/hp/schlumpf/faq.getriebe.engl.htm
Hyena love your balancing system on your stealth, what's the name and specs of the computer plug your using,
I'm figuring you made that yourself.... Or did it come made?
Fred
dimpirate said:You think I might have chain line issues? My dropouts will be 156mm as well....
Rodney64 said:Korpin, I have a 53 tooth on the front with 12 tooth on the rear.
It's worth a go
Rod
Insider said:Hello everybody!
I thought there should be more Phasor Bike owners here...
Anyway, I'm going to be another one
There are no Phasor owners in my country yet, so I'll be the first one 8) It's a pitty because I can't share the experience of usage of the Phasor or try to ride it here before I get mine. And so I decided to explore the E-S forum to get some usefull info and get the best practise regarding the compilation of the bike, some experience maybe.
For the moment I'm looking forward when my Phasor frame will be ready and consider the configuration.
Well, I got a question of how much Watt*hours it usualy takes (per kilometr) in your practise on Phasor depending on your average speed while you ride a simple flat road? I'm going to use the bike not just to have a bunch of fun and drive, but also as a transport to get to my job and back while it's warm season here
Insider said:Hey, Rodney!
Thanx for your experience.
My round trip to my work is the same as yours - about 45km. The road is flat with no hills, a common moscow landscape.
I think I'm going to use LiFePO4 ( 12x(8.4Ah 13.2V) Zippy FlightMax) battery instead of LiPo. Only due to sensitivity to temperature and flammability of LiPo batteries.
I have a final decision regarding motor. I'll use MAC 1000W.
The wheels will be 26' (rear) and 26'-28' (front)
As for the type of riding - city rides mostly, hilly off-roads at weekends (not so reckless)
Trackman417 said:Your still losing a volt a day?
if I see one thing one color stock, I need to get it in that color. Bad right?
Hope you enjoy it.
