Hey there,
Question for you all, as I really could use some electrical troubleshooting with a E-TWOW Booster S+ scooter, which I bought back in May.
After it sat for a few months unused (although correctly and periodically charged), now it won't accelerate when I turn it on. Complicating matters, when I tap the THROTTLE button, the front wheel actually brakes instead of accelerating -- and I can feel the front wheel lock up. Essentially, the throttle is incorrectly behaving just like a second brake button. The display comes on just fine, and there are no errors.
When I brought the scoot, it appeared to need a brand new battery. As the battery level would drop under throttle, I figured it was on its way out and I eventually ordered one (which took a long time to arrive. Recently replacing the battery didn't affect any of this behavior.
The only thing I can think of, is that something I may have disturbed soothing in the lower hinge area, as it wouldn't easily fold down. So I'm wondering if it has to do with a wire that's shorting out. As I didn't take apart anything near the display or buttons, I doubt it's from anything from the top of the scooter.
Other notes:
Finally, please be safe out there! At the time of this purchase, I wound up also buying a refurbished E-TWOW GT 2022 and I wiped out. I shattered my collarbone just two weeks after buying both scooters, and am still recovering from surgery many months later. I was probably going 20mph and likely hit a manhole cover; thankfully I was at least wearing a motorcycle helmet. (I'll be selling it here in Boston, if anyone is interested.)
Many thanks for your help!
Other notes:
- When I first took it out of storage, I first noticed that the speedometer wasn't working when you roll the front wheel - and I don't believe the rear brake light powered on. For whatever reason, the speedometer now works and I'm noticing this braking behavior. Again, I want to "go" and not "stop."
- Again, replacing the battery didn't alter any of these symptoms.
- I can't find any wiring diagrams to troubleshoot.
