O.K.
So in regards to this topic, I think welding only requires concentration... and a welding gun that works quick. I stuck to welding on to the thin strips.
Be prepared and make sure that every weld is done quickly. The flux bubbles, everything has to melt together real fast and let it cool.
I have to agree that the initial workmanship on the battery pack was a bit flimsy. I'm bad, he's worst.
And that wasn't the end of my problems.
Once the pack was together, I tried it for fun. I had 53V and why not!
It failed instantly and I had no way to recharge. So I waited for the charger.
And upon it's arrival, it failed to connect.
And I had to thinker this for a time until I figured that I needed to by-pass the BMS and charge directly.
This pack is made of 16 rows of 11 batteries and had all rows at 3.29V except for one at 1.9V. Something was wrong. Upon recharging directly, I got the overall volts to a level where the charger actually felt everything was charged (57V). I did this in time increments because I'm always afraid with working with electricity and all these stories about batteries blowing up really scare me. But logic prevailed and the battery pack went up to 57V and I though that was good. All 16 cells were up to par within a Volt.
Wrapped things up again, on to the bike, and the way we go.
Wow, that was cool! But the batteries failed constantly. It accelerates but shuts-off. I accelerate slowly and it goes to top speed (49km/h) and then fails again. I keep disconnecting the battery wires and reconnecting and things work again for a small while. But this situation fails the more I do it.
So far, more thinking is needed. What is wrong? Can these batteries handle the power pull of the motor? It works fine with the 36V 20AH. Is the BMS wrong and it cuts off too quick? Is there a block of cells that are wrong? This happened with the 36V pack. One battery went dead and was replaced by the company and everything is A-1 since.
The 'Western United Music' guy has disappeared from E-bay. I can't complain anymore.
I have to unwrap the pack again and figure out what every part does. But I suspect the BMS to be faulty. The weld job on it looks rather ugly, same as your's. Maybe it affected some of it's components?
Any suggestion from people in the know?
Hugues
