Supreme Kay
Hello I own an electric bicycle. I recently bought a LIFEPO4 36Volts 10AH for my bicycle. My ebike controller is rated at 22Amp and 36V. I have a lcd screen SW900, it display the speed, milles travel, the watt and battery consumption. However, I have an issue the battery indicator has 5 bars to indicate the battery level. The bar disappear as the battery discharge. My issue is that when I ride my bike I have 4 bars after about 20 miles of riding I rely on the battery indicator and keep riding. next thing I know I see error 06 (Battery Undervolted according to lcd display user manual) and then I have one bar and the lcd display shutt off I am left with no power from the battery to ride my ebike. I then have to pedal the old fashion way to get where I want to go. I checked the battery with my multimeter at home and I have 36.8 volt, I am assuming that I should still be able to ride . The battery cut off voltage is 25.2 volts, Rated Discharging Amperage:is 15 Amps, Max. discharging current is 35Amp and Max Continuous Discharging Amperage is 20 Amps. My thought is that perhaps the lcd screen may be defective. I mostly use pedal assist, I would appreciate any help to point me in the right direction
