Hey all,
I figured I would post to my original thread for my ebike build.
I built a ebike out of a mountain bike the Diamondback Outlook which is a entry level model, but as was discussed earlier in the thread did meet the criteria on a basic level.
I went for a Bafang 500w geared rear motor.
https://skydrive.live.com/redir?resid=BB4F3F49867A05A7!1021&authkey=!AB93jBf7HYdIq1I
Runs as I expect, I deliberately decided not to get something too fast so I can limit on the dangers of a bad crash, and in exchange of more uphill performance.
I live in a somewhat congested area so there is a limit of how fast I can go locally on the road even with a car.
I used 36v 10ah LiFePO4 battery which was the biggest I could fit inside my frame that i felt could fit nicely. This fitted with pretty much only a few mm to spare, and the handle has to be in the up position to fit, the handle makes a good opening to securing the battery to the top part of the frame.
https://skydrive.live.com/redir?resid=BB4F3F49867A05A7!1031&authkey=!AM1IRX98NilkrWA
The wiring worked out ok, was a bit intimidating at first but I got there in the end, only needed to solder 2 wires aside from the main 2 wires from the battery, these were the battery meter wire form the twist control and the on/off battery signal into the controller, both wanted to be directly connected to the main positive battery lead wire. Rest plugged in fine.
Once built I was eager to take it for a ride but it had been raining lately so I sliced up an Aldi cooler bag to give it some protection, I think It made it look so bad it attracted eyes on the street more then my lack of pedalling.
https://skydrive.live.com/redir?resid=BB4F3F49867A05A7!1036&authkey=!AKQH31lKX8ihoeY
I later sliced up cheapy black bag that makes it look a bit nicer, have ordered some frame cover and bag gear to try out.
https://skydrive.live.com/redir?resid=BB4F3F49867A05A7!1037&authkey=!AMQUMRw8mXoZZgc
Should be able to view all pics of bike here https://skydrive.live.com/redir?resid=BB4F3F49867A05A7!124&authkey=!AJnUNCAYG1vGfwE
Just want to say thanks to all those who gave suggestions, I wouldn't have been able to build a ebike that I would of been so happy with without you guys. Cheers.
