beast775 said:
View attachment 1After looking for a picture from 2007? of my generator way to heavy and stopped the project-ice ebike... wasnt easy to find,but i had the idea of a generator-ice charge bicycle.i learned alot about controllers- regen. but the end result was piss poor regen,but back then the electrics were not as good as today.im watching your build and wish you luck.Mark.
Had a whole lotta diodes etc hanging from the wirings ratnest on the bars.
Hi Mark,
Thanks for that - I found a few pictures of bikes that had started down this path - Most gave up before the end though due to the various problems - Weight of the generator was one, but I did find people who had started to build their own generator the way I did, and I contacted them for advice, but none of them completed it.
One person did make a simple Gen to Wheel direct drive, and throttled the gen to control speed/power, but it seems getting the gen lightweight was half the problem. I can relate to the crows-nest wiring - I have a lot myself. I'm just waiting on a few extra parts to start building it all into a small box that's fully self-contained.
A simplified diagram of the entire setup is here -
Building a generator small enough to do the job was the first problem - The original concept models weighed about 6kg, though I am trying to almost half that and have gotten below 4.5kg lately.
The second challenge was controlling the motor, and there were no commercial servos to do the task and I didn't want to go digital, so I used a hysteresis system that would throttle-back really quickly if the float voltage of the batteries was increased, but would use the hysteresis effect of the ripple coming from the generator to adjust charge to optimum levels. This means it can move quickly when it has to protect the batteries from over-voltage or over-current, but will also push a lower voltage in when they are flat, and continuously increase the voltage until it charges the batteries to about 85% capacity ( 85% means the voltage under generator never exceeds the maximum voltage under battery alone, so there's no increase in power - for legal reasons where I live ).
The effect while riding is that if I go WOT, the bike accelerates hard, then as the load starts to cause the batteries output to drop ( due to internal resistance ) the generator detects it, and continues to throttle up, maintaining a constant voltage under operation, so up hills, the note increases, while down hills, it drops off suddenly into an idle. Back-EMF above the boost level filters back and trips the converter down really steep hills and the sound from the generator is so quiet it sometimes makes me think it's stopped. If it's putting out high power and I throttle down, it also backs off instantly on the motor, but slowly throttles back to whatever voltage is required.
Designed like this, it's fairly simple, but it does comply to EN15194 for the european standard. Maximum power is nearly a kilowatt, so I light up several lights all the time to make riding safer.
Did you get yours running? Tell me how your attempts went? I'd love to hear more.
I've run about 20 hours on this so far, and over 300km... So far it's holding up pretty well. Also, the main moving parts other than the generator and motor are all 3D printed, so can be replaced every 100 hours during a quick maintenance.
Regards
David.
