Hi folks,
After my success with my ebike (900 miles and counting!) I want to move on to something larger. I've been doing some background reading and formulating some ideas but I have a question about electronic speed controllers for brushless motors I hope someone can answer.
As I understand it, if a vehicle is stopped and there is no clutch between the drivetrain and motor if the throttle is floored the motor(s) will pull lots and lots of current (spike) which overloads the controller. This is why folks simply can't use a model motor with a model controller without being super careful.
I've been thinking of ways around this; couldn't a resistor be placed on the DC portion of the controller (battery side) to limit the current spike to a managable level? sure it would dull the acceleration from a standstill but it would seem to solve this problem.
Incidentally I'm not going for massive acceleration so I don't care if the performance from a dead stop is not as good as it could be with a infinite current ESC.
Thanks!
Edit: I'm toying with now with 3 or 4 turnegy motors (the 6500 or 7000 watt versions) combined with 3 or 4 180 amp (360 amp peak) marine controllers (with water cooling enabled). I'll hook these up to 4-5x lead acid batteries in series. It just occured to me that each battery will have internal resistance plus all the wires and connectors, so this might actually limit the peak current by itself....hmmmm
Thanks!
