Made some progress today - swing arm is tac -welded together. stopped at the pivot & BB bracket area. Still have some final decisions to come to before striking an arc.
So I measured my clearance in the swingarm regarding wheel diameter. I can run anything from a 20" - 26" tire diameter. I am going to have to start thinking about different mounting brackets for the rear suspension depending on what wheel diameter I am running. I will need some kind of "riser/spacer" when running the shorty wheels. I also have to consider BB height and decide if I want to just run short armed bmx cranks (140-150mm) when I am running these 20" wheels, and then run longer, conventional length crankarms when (if) I switch back to a taller wheel. This is why I stopped where i did on the swing arm...
Everything ended up pretty square/straight....
So if anyone with a sharp eye can see, I decided to re-cut the sections of the swing arm that attaches to the dropouts; on my first attempt, I just notched the inner side of these sections to accept the dropouts. Today I decided to do them over again, and slot these sections down the middle to allow for more welded surface area/ strength...
I didn't bother changing my wire today to a smaller guage - thus the glob tac welds.... Plus she's mad at me for neglecting her all last month..
On another note, I was having a hard time sourcing a tube with an ID that could fit ANY conventional bicycle seat post size. Fortunately I found 1 - 3/8" OD X 1.245 ID tubing (.065 wall)
- turns out this works very well with a 31.6 mm seat post.
Bonus....just happen to have 2 different posts of that size here at the house. I was going to weld on a pinch bolt/nut to secure to post, but the fit is so perfect, I think I can get away with slotting the backside of the post and using a conventional 34.9 seatpost clamp/collar...
Its such a motivator when your project starts moving from 2 dimensions to 3 dimensions!
Len
