LI-ghtcycle said:
I am really hard on pedal cranks, I have always up-graded to sealed bearing types on all my bikes because I am "masher" not a "spinner" and the typical square crank spindles just don't take the abuse, and since this is an extra wide spindle, I think the effect is magnified.
Did you spall out the races on the one you have, or are you replacing it preemptively?
The bearings of a loose ball bottom bracket are usually MUCH stronger than the cartridges in a unit BB. They're not only bigger, with bigger balls, but they are oriented to better withstand the forces of pedaling. They fail earlier either from contamination, poor lubrication, or incorrect bearing adjustment. But it's true that they do often fail earlier than a sealed unit would.
If you have a loose ball BB that is difficult to replace, then my advice is to overhaul it yearly or whenever you can hear it, use lots of waterproof grease, and take care to keep it in proper adjustment.
