Hiya all.
Just after your opinion on this issue I have.
I have a rear Ezee motor, Ezee 25Amp controller and 48v battery.
The motor cuts out when I pull away giving it full throttle. The wheel starts to turn then after about 0.5 to 1 revolution it stops. There is still voltage at the inline power meter so I don’t think it’s the battery.
I have checked the Ezee controller and it flashes 8 times which means a hall sensor fault.
The rest of the time it rides just fine, climbs hills like a beast, and as long as I accelerate off the line gently it works faultlessly.
So is it likely to be a hall sensor in the motor at fault or could a dodgy hall sensor wire/connector cause this.
Thanks in advance.
Thanks in advance.
