Bor_Ed
I've noticed that current LiFe cells tend to have 'best' charge rate at 0.25C to 1.0C as highest recommended charge rate.
I'd need a pack that can be charged at around 1-2kW of power from the grid to be able to charge in sane time.
Do you guys have any sane and affordable cells to be used with higher than that charge currents that you can recommend?
Screw ends at the cells is preferred so it's pretty much cylindral since pouches require more work to assemble.
Battery pack will have 15 to 40Ah so I think getting small (8Ah) or so headways to drop to paraller.
