Spicerack
Wow you can really see where those magnets were moving around the hub shell! Obviously all the epoxy failed- must be pretty low temp rated! If you had massively overheated your motor, the windings would be dark brown and the strings around the windings burnt, which they aren't.
Just an idea- try sliding a shim of standard copy paper between each magnet and see if that takes up the gap. Realistically I don't think that gap will make much difference at all though. You could also epoxy the broken magnet back in and see how it goes- you might get away with it...
