I have 2 bullitts. One came with ezee conversion setup with a Grin torque arm - 1500w was the top output and it had no problem using just the 1 torque arm. The other I installed a crystalyte setup running a 60v battery - it spits out 2200watss off the line.
For the 2nd I mimicked the setup on the first one and installed a torque arm. I found out within a month that the power output overwhelmed the single torque arm and pretty soon the axle jumped out of the fork ends after the non torque arm side spread out. I had another torque arm sitting around so I installed it on the other side. I marked the meeting points with a sharpie and check them all the time - no movement.
I am swapping out the lower powered setup on the 1st bullitt and noticed there is minimal spreading of the fork ends on each side. The system has had a motor since before I bought it - not sure how long it had been installed. I did the same thing with the new setup and installed torque arms on each side - GRIN. Everything seems to be held in place with snugging down the bolts/washers and the torque arms on each side.
What risks am I running here - if any? I have been using the double torque arm setup on a very powerful motor for 4 months now with no visible movement when the markings are checked. I am running the system industrially, delivering beer for work - so lots of weight with beer, costco runs and laundry.
