michaelplogue said:For front suspension forks, you might consider a springer-style setup. These ones will fit most bikes. One would probably want to have some beefier steel rockers made, but these should work just fine with a front hub motor.
The fork is not designed for a hub motor, absolutely not.
It will not work for your application.
diver said:the springer works really well for me so far. on acceleration the spring seems to dampen the torque of the motor to the stem. I had to weld on the stems on forks for the brakes. over all i really like it. No more handle bar vibration over bumps. I hope it holds together ,only time will tell
It could be stainless steel. I used stainless nuts, washers, and, threaded rod, when building my wind generator.D-Man said:I tried to find a steel one. Bike shop sold me one they claimed was steel. Actually it looked steel till I put a magnet on it. Had a shiny finish on the outside. Dumb bike shop.
