Arbol
KarlJ said:having purchased a couple of EM3EV packs now, i can tell you they are a very well made pack.
They dont have an output fuse as the BMS takes care of this, ie short it BMS will drop it out anyway.
99% sure the average punter would not be able to buy or if you did it would have no warranty a pack with no BMS (at least from EM3EV)
Pack safety for an ebike should boil down to cell types, Hobbyking Lipo's have a bad rap for setting fire to themselves but i'm sure many failures
of this type of cell are self inflicted by over discharge, incorrect connections when splitting apart to charge or reassembling to ride.
A hobbyking type battery has cell taps for balancing but no on-board BMS.
My point is there is plenty to consider which also affects the requirement for such things as mentioned in above posts,
EG: if your battery is held on the bike by duct-tape it will likely rub and over time and something will turn ugly someday.
there are dozens of things to think about when building a high-powered bike and like everything in life, normally compromises are made.
Having built 2 EM3EV ebikes now, one with the bottle shaped battery and the other with the frame bag idea, i can say that the frame bag is excellent,
makes for a very neat job and a bike build can take under an hour to build.
Step 1 Decide what you are going to use it for.
Assuming whatever the use it will be capable of 50km/hr quite readily.
Whatever category Pick a bike that has well above average brakes (my 1st mistake).
If this is your first ebike build and you intend to ride it on bikepaths and the road, there is little point in having more than about 2000W (which an 8T mac appears to take happily)
A good ebike (or bike) is the sum of ALL its parts.
Me, next bike will be bigger, have at least font suspension, will be purchased with decent discs and calipers, plenty of space for a battery of 14S 18650's ~15AH
Aim will be for a rear drive as i've done front drive and if i need more grunt, i'll add another motor!
KarlJ, thanks for your detailed answer.
It is interesting the fact that em3ev has no output fuse. Instead, em3ev has balance wire fuses. So then, probably the balance wire fuses are there to avoid problems in a parallel "brick" contaminate the rest of bricks. And the BMS will act as a fuse if there is a catastrophic event affecting all or most bricks.
I want to use 18650 cells, clearly no lipo. Lipo is a no-no for me, at least for normal usage (probably OK for fast testing).
I want to put my battery inside my triangle, either with a polycarbonate box, or ideally, creating a metal box on purpose. The fact I want to build my own battery is basically due to this.
I am based in Europe, so I will limit myself to 250W motors. Mostly urban usage, max legal speed of 25km/h (so max, max in real terms around 30km/h). And yes, I know that for these levels of power and speed, I would rationally be better served with a "normal, pre-packaged" 36V 10Ah / 15Ah battery. But I want to build my own battery, anyway.
I want to have a hydraulic disc brake front and a mechanical disc brake rear (and a HWBS inside the triangle box).
And I am trying to find a nice donor bike with rear suspension.
So, yes, all your comments fit very well with my design plans.
Mmm then, which are good (resettable) balance wire fuses? Is there a model / brand somebody could recommend? Clearly, these fuses should be for 3.7V, but I am not sure for which amperage. A main fuse amperage probably has to be slightly above the max amperage of the controller. But I have no idea of which is the max amperage a balance wire usually withstands. I guess that this max amperage at the balance wire is significantly less than the max amperage of the controller, but I do not know how much.
