@whiplash, My concept of a "hydraulic coupling" is a hose connection, so you must have meant pump. Most of my 2wheel exp is in the motorcycle field, and yes 80-100% of braking comes from the front wheel. Here are some apps experimented w/ by yamaha:
http://www.topspeed.com/motorcycles/motorcycle-reviews/yamaha/yamaha-wr450f-2-trac-ar18231.html
http://www.motorcycle-usa.com/269/4240/Motorcycle-Article/Yamaha-R1-Ohlins-2WD-Review.aspx
These hydraulic motors are fixed bent axis piston. The axis can be varied to make an infinite ratio pump(or motor), this would allow an electric input motor to run in it's prime rpm range for eff.
In short, yes it could be done. But w/o an outrunner hyd motor design, I see this as a reduction in eff due to weight and complexity imo. Been trying to conceive an outrunner design, it's harder than it sounds.
ptd said:
firstly, is there a way to get this to work with dc? it seems like ac is a requirement, but what if you were using it as a diversion for a power source that was powering down, and you wanted to divert the power from powering the motor, to recharging the battery pack? i get the impression that it results in only one cycle, which would be low in terms frequency. but could you have something like a mosfet switch it on and off for you? kind of emulating ac? maybe redirect it to some kind of temporary cap? and then output at 1/2 the duty cycle? like, double the power for half the time?
secondly, say you had a pair of concentric coils, the inner, able to "slide". the outer, wound in such a way that a variable number of coils would be adjacent to the inner, ie, the "thread (or coil) count" increased or decreased. would this result in an ability to take input, and output the same power (minus the loss of the transformer), just at a different voltage and amperage?
lastly, does the concentric arrangement negate the need for a core? because of a reduction in air gap?
sterling and dry ice, too funny, but you could ditch the ICE and get a fresnel lense, lol
Yes, transformers are AC only. Yes, if you double the voltage the current is halved and vice versa. Yes, DC can be converted to AC for such a purpose, this what the controller does to supply power to most brushless motors(abit obvious for this forum). The alternator in a car creates AC power, which in turn is routed through diodes (one way only) to convert to DC. So if a hub motor is generating AC current, it has to be converted to DC for storage, then returned to AC for consumption. This is what is meant by "stacking inefficiency". From what I remember, to use caps for storing AC two are needed and the charge bounces back and forth between the caps (we used 3 in a exp). The amount of energy stored is not high, and syncing it back for use would be a BIG HURDLE.
The iron core is absolutely necessary, it has to do w/ collapsing magnetic fields(live for physics may know more details). Lamination of the iron (layers of sheet metal) greatly improves the eff. Over time the magnetic forces push and pull so much as to cause physical vibration, creating this sound is a lose of energy. Here is a demo of one of the more interesting things I learned in advanced physics:
http://www.youtube.com/watch?v=kCq1u_x07S8&feature=related
Magnetic fields have a square root function in relation to distance, i.e. double the distance get 1/4 of the magnetic flux. So air gaps reduce eff greatly.
An idea I tried to promote @1t was pizza delivery using high cap energy storage, which would be good for about 10-20 miles. When the drives returned to the store, they would park over a charging stations which hold half a transformer. This same charging technique is used for modern rechargeable electric toothbrushes, nothing new. Having worked the #s, it would take about 80lbs of high energy caps to do this.
It's not chocolate and peanut butter, but unique: http://www.youtube.com/watch?v=RNg-aWYcuOQ
