Pete1961
Hi All,
New guy here, have a golden HBM 36 brushless, fried the controller on a long hill & am trying to determine if the motor is still OK. Have 0.4 ohm res reading across any two of the three phase wires & inf. to the casing. took cover off motor - there is no sign or smell of burning so think main windings OK, & reassembled motor.
Hall sensors: Put 5v dc across red & black (observing polarity) put meter probes across black & the three signal wires in turn
green = 0.01 to 0.04 volts as the wheel is moved slowly throu 60 degrees. blue exactly as green. Yellow 0.04 to 0.1 volts at 60 degree peaks (have verified meter on correct scale by putting it across a torch cell, reading confirms)
Have seen vid on youtube 'testing hall sensors' but he seemed to be getting higher peak readings, just want to know what is typical for these values
The HBM 36 is a model now discontinued by golden island as they seem to have a new range. I was running it with the stock
(shenzhen ???) controller on 36v SLA. Worked well for over a year. Am considering either replace hall sensors or a sensorless controller as I need a new controller anyway. One of the failings of the golden controller vs xlyte's was said to be that the former had no heat sensing shutdown in it, while the latter did, does anyone know if this has been addressed in the golden/shenzhen units?
Think phase wires just beyond controller out connector overheated & caused a short frying controller, don't know what effect this may have had on hall system, any advice greatfully received
Pete
Pete
