NeezyDeezy said:
Thanks Amberwolf. I'm going to be running a 8T GMAC off a L10 baserunner in a 26" wheel on a KHS pro soft-tail bike, with a EM3EV super shark 17AH 52V pack. Notably I will also be running a CA3. I have a big full triangle on the frame for the battery with room to spare, so I guess I can just stuff the baserunner and any cables in a bag in the unused part of the triangle. Not very elegant, but I didn't want to pay a $300+ premium for grin's battery just to be able to keep the baserunner in it. The bike looks just like the one below. The second photo is my best guess for where to run the baserunner up into, though I'm not thrilled about it, in part because I'd have to run cables along the toptube for the CA and the seattube to the battery and the chainstays to the rearhub.
I don't recommend putting any controller in a bag, as it won't have any airflow to cool it off; all the heat will be trapped inside the bag with it. It may not outright fail, but it will age faster than normal, and it might have unexpected behaviors when it gets too hot.
There aren't many good places on that frame to put things. For something flattish and wideish, you might be able to tuck it up under the seat itself with a relatively simple mount, though that makes the wiring even longer.
If the BR is fully waterproof, you could mount it "under" the battery pack, on the other side of the downtube from the cradle or mount. There are tube clamps available that look something like these
https://ebikes.ca/shop/electric-bicycle-parts/battery-accessories/battanch-clamp.html
for various ways of mounting flat things to pipes and tubes. Your local hardware store may have something, or at least something adaptable to the purpose. If not, the internet is full of things, some examples
https://www.google.com/search?q=tube+clamp+mount
or you could design something to be printed in 3D plastic or machined in metal. (the former is probably cheap, the latter I expect costs more).
Using similar mounts you could even put the BR down by the motor (shorter phase wires that way, since there's more of them and currents are usually higher than battery currents). It could be put at the intersection of the seat and chainstays near the dropout, or in front of the wheel at the intersection of seattube and chainstays.
