danielrlee
I'm probably worrying about nothing, but following a minor modification to my Grinfineon controller today (fitting an external switch), I have noticed a sequence of LED flashes that I don't previously recall.
When I turn on the controller the sequence is as follows:
2 quick flashes, 3 quick flashes, then a steady flash every 0.8 seconds.
I recall the steady 0.8 second flash, which as I understand indicates everything is functioning correctly, however don't remember the additional quick flashes before the mod. The controller appears to function okay with an unloaded motor, so there doesn't appear to be an issue. Chances are it's always done this and I'm just paranoid I've cocked something up.
Is anyone else with a Grinfineon controller able to confirm the same startup sequence? Thanks.
