safe said:What I'm doing is radically different from anything I've seen.
Has anyone seen a true "Halbach Disc Motor" being built? (that attaches to the rear wheel)
There are lot's of "axial flux" motors of either Standard or Halbach design (both one sided and double sided), but no one seems to have made the jump to a pure ebike solution. Unless someone beats me to it I'll be the first to create the Halbach Disc "ebike specific" motor.
Boing?Toorbough ULL-Zeveigh said:patent granted just 2 months ago to boing.
gogo said:^Hehe
Ya where the hell is that troll? I kind of miss him in a wierd twisted senceAussieJester said:Safes going to be pissed hehehe
KiMsafe said:What I'm doing is radically different from anything I've seen.
"Running Amok" :lol: I just spilt my coffee! :lol: Sounds like safe... The forum is a bit boring without the entertainment he adds.AussieJester said:Hes running amok on Motoerdbikes.com now if you want to get your "Safe Hit"
His threads are pretty much just alot of him rambling post after post so he
would probably welcome some 'friendly faces'
KiM
Lower efficiency for extended missions... ?As previously described, gaps 380A and 380B may be implemented with large dimensions such as, for example, up to approximately 3.0 inches. In such embodiments, this increased distance between Halbach arrays 310A and 320A, and between Halbach arrays 310B and 320B can reduce the efficiency of electric motor 300.
However, such embodiments can nevertheless be useful in applications where efficiency is less important. For example, it is contemplated that such embodiments may be used where one or more rotors of an unmanned aerial vehicle (UAV) utilizing electric motor 300 may be pre-spun (for example, up to several thousand revolutions per minute) using a ground power source such as a battery or direct power connection. In this case, the stored rotational energy in the rotors could then be used to rapidly lift the UAV to adequate surveillance altitudes (for example, several hundred feet) without requiring electric motor 300 to expend its on-board power source to provide such initial vertical lift, thereby permitting the on-board power source to be retained for extended aerial mobility missions.
Ya that's safe.... My head hurts now after reading that nonsence... Thanks TylerDurden :lol:TylerDurden said:Lower efficiency for extended missions... ?
Chalo said:Eek. Coker rim? That'll make it "interesting" to try to maintain a constant rotor gap.
Gavin53 said:New to this site, but not the topic.
Interesting, over a year ago I mounted a bunch of magnets on the rim of my front wheel and set coils up in the fork to give me a push.
Getting the phasing exactly right to have any efficiency at all required a faster processor than my MSP430 so I gave up.
Gavin
