shortcircuit911
Hey everybody, I'm a noob with a couple questions. I have a 36v 500w bldc hub motor that has been acting up. Basically the motor would make a loud noise when spinning, and would have dead spots that required me to spin the wheel in order for the motor to engage. This led me to believe that the hall sensors had failed. So I recently received some honeywell ss41 hall sensors and replaced only 2 of the 3 in the motor. I only replaced 2 because thy are so hard to get into the existing space with out breaking them. so I took a shot with replacing 2, and now the motor doesn't spin at all. Could this be from mixing hall sensors? Also I couldn't get the sensor to sit al the was into the square notch. Any suggestions or advice would be greatly appreciated.
