Well its a gorgeous day here in Brighton (UK) and I thought it might be time to try out my new rewired bike. I just had to fix a new throttle and then everything would be up and running.
BOOM.I'm not totally sure what happaned next, I think I connected all/the wrong throttle wires together, or and something else happened at the same time. The battery fuse had blown. With the controller opened up I can't see anything looking obviously damaged.
There is continuity between the positive and negative inputs and also between the positve and the yellow phase wire (see pic). If I measure the resistance of the first two fets its almost 0 unlike the other 4 which measure either 120 ohms or 1400 ohms between the far pins.
Do I have a shot at fixing it? I have a half decent multimeter and a less than have decent understanding of electronics and am ok-ish at soldering.
[/code]
[/code]
