iangreenhalgh
- Joined
- Dec 24, 2015
- Messages
- 200
Hi folks
I need to buy a set of brakes to replace the crappy things on an MTB I just electrified with a 48v 1000w hub motor on the front. A disk brake won't fit, the frame lacks the brackets and the forks aren't wide enough to fit the motor with a disk mounted on it.
So it's rim brakes.
After a couple of hours of reading I'm confused. I want a set of brakes that are suitably high performance but not too expensive. Shimano and Avid seem to be the preferred choices.
Some guidance definitely needed as I've gotten thoroughly confused.
So it's rim brakes.
