Hi guys
I have some 6ah power tool betterys i would like to repurpose as a battery pack for an electric mountainboard. As far as i know they use 5s2P 18650 cells with 15a constant discharge and 3ah/cell. I plan on making the pack 10s but i am unsure how many i need in parrallel If i wanted to run 2 motors with a max of 90amps. Am i right to assume this is 90amps required divided by 15a constant discharge per string? Also these batterys already have a bms in the 5s2p configuration so would it be possible to have seperate bms and then wire the individual packs in series parrallel as required or would i need to make the pack with a new bms?
Any help is much appreciated.
Thanks
Shane
Thanks
Shane
