Hi Nick
Ya definitely want to get up close with the ePPG folks! Did you see the "E-Pac" that Yuneec International is offering (claims to offer?):
http://yuneeccouk.site.securepod.com/paramotor_products.htm
From that page:
"Powerful, Ultra Smooth and Very Easy to use, E-Pac features a new Direct Drive Sensor Controlled motor, Sensor Speed Controller and Lithium Polymer batteries all built into a practical, strong, ergonomic moulded body unit. These key features, together with a 4 piece 'aerofoil profile' propeller cage, a 1.2m 'Quiet' prop and E-Pac's featherweight 'easy grip' handcontroller with integral LCD flight data display, combine to create one of the most advanced and futuristic paramotor power units available today."
E-Pac Outline Specification (specification and design subject to change)
Power Unit Yuneec 'Power Drive' 160 Power Source: Plug and Play Battery Packs
Type: Direct Drive Type: Lithium Polymer
Diameter: 160mm Total Voltage: 55.5v
Control: Internal Sensor Packs/ No. Cells 6x Packs (15 Cell per Pack, Total 90 Cells)
Voltage: 55.5v (Constant) Total Amperage: 30Ah (Supplied) 60Ah (6+6 Pack Option)
Weight (6 Packs): 10Kg (30A)
Propeller Yuneec 'Q-Prop' Charger: Yuneec E-Charge
Size: 1.2m 2 Blade System: Full individual cell monitoring/balancing
Specification: Carbon with quick release system No. of Packs: 3 Packs at a time
Charging Time: Approx 1.5hr per 3 Packs
Motor/Prop Output Flying Time
Thrust: 50Kg (55.5V) With Supplied Pack: 25~35mins (At variable power settings)
(Using 6 pack standard configuration)
Speed Controller Yuneec 'Power Block' Statistics
Voltage: 75v (Max) Weight inc. Batteries: 22~25Kg (Ready to fly - no wing)
Amperage: 250A (Max) Body Types: Moulded Plastic/Fibreglass/Carbon
Audible Alarms: Power On / Start / Tempreture Propeller Frame: Profiled Aluminium
Start Protection: 5 sec Slow start (Initial activation) Frame Diameter: 1.25m
Internal Cooling Upgradeability
Motor and Controller: Motor Integral Fan Pressure System Power Packs Additional battery packs can be added
internally and externally ot a maximum 60A
Hand Controller Optional Items
Functions: Start, Stop, Throttle, Cruise. Batteries: Battery Pack 5Ah (Each),
Display 600x400 pixel LCD display Battery Pack 30Ah (Tri Pack)
Data Information: Rpm, Amperage, Voltage, Motor/Controller Tempretures
Data storage: All relevant E-PAC data Pricing To be announced Spring 2008
Please note: Due to continual development the above specifications are subject to change. All estimated flying times are given from current testing and must be considered approximate. Times will vary depending on pilot weight, wing used and other varying conditions.
Roll yer own, or maybe just buy off the shelf:
http://www.hovpod.com/index.html
cheers
lOcK
