Dingo2024
hi, as I have posted in my build log my bike died this morning
http://endless-sphere.com/forums/viewtopic.php?f=6&t=18130&start=30
I opened the throttle at a road junction and it went dead..no CA display or lights on the throttle; got it back home and started to look for what the problem was (although I am not too experienced in this)
I have a meter and the battery and controller are removed from the bike. the inline fuse has not blown
I got the CA to function by disconnecting the controller it reads 50.4v battery voltage (48v 16s cell_man pack)
The controller is apart now and nothing appears burnt on the board but if you put the meter across the power leads (red and black) it reads open circuit..is this correct
what else is there to check? how do you test the motor with a meter?
the throttle was stripped down and appeared ok
any help would be greatly appreciated
thanks,
Ian
thanks,
Ian
