BalorNG said:
If you have steep hills, and you have trouble riding up them, you don't actually need more POWER, you need more TORQUE capacity, because the motor like you have have pretty poor torque capacity - a 350w rated geared motor like 2x better than 1000w DD motor, basically (I've did tests myself). Of course due to internal gearing it has less top speed, but do you really need to move faster than 30 mph on fully rigid bike with terribly aero like you have?
A 1000w *geared* motor will be MUCH, much better at climbing and lighter, too - because it is going to MUCH more efficient when climbing, which is what you actually want.
Which geared hub would that be. I noticed that even a MAC 12T melts in a few minutes on only a 10% grade, and can't find any other geared hubs that can do better.
https://ebikes.ca/tools/simulator.html?motor=MMAC12T&batt=B4823_AC&cont=C20&hp=0&axis=mph&frame=mountain&autothrot=false&throt=100&grade=10&wheel=26i&mass=110
*unless you're talking about oil cooling the geared hub
You can't increase torque without increasing power, Power and Torque are outputs, not the variables. The variables that contribute to torque are voltage and current.
If you have 80V @ 70A or 70V @ 80A, the torque is the same (top speed changes but for the torque curves before drop off):
https://ebikes.ca/tools/simulator.html?motor=Leaf%205T&batt=cust_80_0.05_24&cont=cust_70_200_0.03_V&hp=0&axis=mph&frame=mountain&autothrot=false&throt=100&grade=0&wheel=25i&mass=110&bopen=true&cont_b=cust_80_230_0.03_V&motor_b=Leaf%205T&batt_b=cust_70_0.05_24&wheel_b=25i&mass_b=110&hp_b=0
To increase torque, you either need to increase current:
https://ebikes.ca/tools/simulator.html?motor=Leaf%205T&batt=cust_80_0.05_24&cont=cust_70_200_0.03_V&hp=0&axis=mph&frame=mountain&autothrot=false&throt=100&grade=0&wheel=25i&mass=110&bopen=true&cont_b=cust_80_230_0.03_V&motor_b=Leaf%205T&batt_b=cust_80_0.05_24&wheel_b=25i&mass_b=110&hp_b=0
or increase voltage:
https://ebikes.ca/tools/simulator.html?motor=Leaf%205T&batt=cust_80_0.05_24&cont=cust_70_200_0.03_V&hp=0&axis=mph&frame=mountain&autothrot=false&throt=100&grade=0&wheel=25i&mass=110&bopen=true&cont_b=cust_70_200_0.03_V&motor_b=Leaf%205T&batt_b=cust_90_0.05_24&wheel_b=25i&mass_b=110&hp_b=0
both of which increase power, and torque.
