BVH
- Joined
- Mar 26, 2009
- Messages
- 411
I've checked my CA stand-alone version installation at least a dozen times and it is installed as per the directions. The wires on the "controller" end of the shunt go to the Kelly controller battery input terminals. The wires on the "battery" end of the shunt go to the Lipo's thru my Kilovac relay (and protective Schottkey diodes) Polarity is correct. Yet, All of my Watt and Amp readings are negative. The Voltage readings are correct. I don't have Regen, yet the CA shows regen taking place - another indication of reverse flow. The other symptom is that on the first screen, the lower left field I have set to show Watts being used. The display of Watts is negative as I increase load but it seems to be an accurate number (even though it's negative) but after about 4 or 5 minutes, it will not display anything but 0 - 3 negative Watts no matter how much load. If I reboot the CA, it will again show negative Watts and will revert back to 0 again. This is the newer CA with improved mount, I just purchased it. Everything is telling me I've got it installed backwards but the markings on the shut say otherwise. This is the stand-alone version so I am assuming the external shunt is properly calibrated to the head unit out of the box.
