steveo said:
BASICLY IMO
YW charger (crap.. don't waste your time)
YW bms (again Crap don't waste your time, I had nightmares with my dewalt bms, I don't trust anything yardworks is going to include with this $109 battery; Use a 3rd party balancer for god sakes; I think a lipo blinky balancer will do a heck of a better job.
Battery testing to come...
p.s. What would you say is a safe charge rate for these cells? What it the safest discharge rate for these batteries also say for a 20s pack?
Have you found any specs on the batteries? I wish i had the battery info here with me just curious to find some info on the cells themselves.
-steveo
Cool ! Wonderful, I'm looking forward to more feedback and detailed testing results.
Yes, charger and BMS, kinda crappy, but not TOO bad (for the price) as baseline or "training wheels" until we get/build some better ones.
Safe ? I dunno, we're doing our own R&D here. In a post in first 2-3 pages the numbers on batts were deciphered to indicate 6 amp-hours (which we already know), nominal voltage 18.5v (normal for 5 LiMn cells) and max discharge rate of 31 amps (5+ C). I've never hit the BMS current limit but I think someone (NutsAndVolts?) mentioned they cut out around 30 amps or so.
IMO, safest, most life enhancing charge or discharge current for any battery is 0 amps, or just slightly more.
There's a nice graph here: http://www.batteryuniversity.com/parttwo-34.htm that indicates 1c charge/discharge might last 500 cycles with 15% or so drop in capacity. 2c might last 200 cycles with same 15% drop, and 3c perhaps 50 cycles.
Maybe LiMn is better, I don't recall right now.
EDIT: Oh, here it is: http://www.batteryuniversity.com/partone-5A.htm :
In 1996, scientists succeeded in using lithium manganese oxide as a cathode material. This substance forms a three-dimensional spinel structure that improves the ion flow between the electrodes. High ion flow lowers the internal resistance and increases loading capability. The resistance stays low with cycling, however, the battery does age and the overall service life is similar to that of cobalt. Spinel has an inherently high thermal stability and needs less safety circuitry than a cobalt system.Low internal cell resistance is the key to high rate capability. This characteristic benefits fast-charging and high-current discharging. A spinel-based lithium-ion in an 18650 cell can be discharged at 20-30A with marginal heat build-up. Short one-second load pulses of twice the specified current are permissible. Some heat build-up cannot be prevented and the cell temperature should not exceed 80°C.
So LiMn does not age the same way other Lithiums do. They maintain low internal resistance through their life (unless abused). Cool ! I'm still not quite sure how they age; must be lower capacity, even though resistance stays low ?
"Battery University" is a great, informative site. Start here: http://www.batteryuniversity.com/partone.htm and progress to part two when done.
Of course while riding and charging, current is not constant, except perhaps in CC phase and at max throttle. I wonder if fan or speed wind cooling would increase life at high C rates ? (Imagine Homer Simpson adding "speed holes" to batteries.
IMO, you should be able to charge just as fast as you discharge; the heat physics are the same I think both ways. So in theory, you could charge at 30 amps, but that would probably only be good for 2 minutes or so with discharged pack before you'd go to CV phase with current declining to keep cells at or under 4.2v.
I think I will stick with 12 amps as max charge rate; but I've been considering 6 amps or so to increase life and because it would only increase charge time by maybe 15-20 minutes or so.
Charge and discharge rates in amps or C are the same no matter if you have 1s or 100s. Same current flows through all batts/cells, assuming you have no balancing shunts or whatever. Parallel is different of course; in best case your parallel packs are well matched so current divides equally between each side.
