majornelson
I'm building out a traditional steel road bike with a small rear hub motor (Q100CST) with a small sine wave controller and PAS only. I bought the mounting box for the controller and also a small Lunar battery (with seat bag) that will go under the rear seat.
Mounting box is here:
http://www.greenbikekit.com/controller-case.html
The case will mount on my seat tube and I'm looking for some inspiration on how to hide the gaggle of wires and connectors that come from the controller or a different approach to concealing both the controller and cables. My only inputs to the controller will be battery, motor (power and hall sensor), one brake cutoff, LCD display,one speed sensor and the PAS sensor. I'll cut the additional connections.
Questions:
1) Are there any other preferred connectors to replace the standard ones on the controller?
2) Should I just cut and solder the connections (I hate soldering and suck at it)? Or use some other type of smaller connectors? For example the hall sensors are only 22 ga but the connector is huge.
3) I've used a frame bag recently to hide all but I'm after a more traditional (vs. classic) solution for this bike as it has drops, etc. Any other ingenious ways to hide the controller and connectors? I'm not afraid to cut and have built a number of bikes. But I've always shied away from making permanent connections to the controller from the various parts.
My last build with the frame bag (city style bike with a more classic design) but I'm looking for something different this time...
https://endless-sphere.com/forums/viewtopic.php?f=3&t=84433&start=25
Pictures of the case and controller attached.
Any ideas appreciated!
Lee
Questions:
Lee
