bigmoose said:
If you make your axle with the capability to circulate, before you go to all the time, expense and weight of adding the water channels; I would sure like to see you just circulate the Dextron. I'll bet you will achieve all the cooling and performance you desire with a single fluid coolant.
I have so far reduced some weight from the motor. I took off the disk adapter.. Milled the covers.. The stator... Etc. the aluminum inserts, water, hoses, radiator and pump I estimate to be 4-8lbs... 1L water is 2.2lbs... I think I can compensate elsewhere as this isn't a bicycle.
I think this will be a good test. I thinks that ultimately it is more tuneable and more appropriate.. It's not a 50cc engine with tons of surface area, fins, and a proven method of agitating the oil inside. I hope to see.. It's good fun for me to make this modification.
I would like to do water cooling to a stock motor the right way and get before and after data to see what is really happening. I don't think anyone has offered such information on ES...
Edit:
I was curious just how much more the motor will weigh. Here is the weight of the cooling channels plus 50/50 ethylene glycol/water solution in the cooling channels plus 8 feet of hose and its fluid.
99.85 grams ethylene glycol (89.7 cm^3)
89.31 grams Water at 30C (89.7 cm^3)
520 grams Al Channels on each side (192.4 cm^3)
95.57 grams PTFE tubing 5/16x1/4"x8' (43.44 cm^3)
3.22 grams water (3.1275 cm^3)
3.58 grams ethylene glycol (3.1275 cm^3)
811.53 grams, 1.789 lbs. add a little bit for 24 cap head screws.. And fittings.. Subtract a bit for milling stator etc. Radiator and pump I'm estimating are 2-3 lbs total. Say 500 cm^3 in radiator adds another 500 grams.. 1.1 lb. So 4-6 lbs total.
Dextron at 500cm^3 is about 422 grams, .93 lbs. this is a bigger hub.. It may need more than the typical to achieve good thermal transfer. Bigmoose did you mean to circulate the dextron to the radiator? That would be close to the same weight.
