thedarkcarver
100 µW
Raith Vengeance Carbon 4WD Specs:
DECK MATERIAL: Carbon Fibre
WHEELBASE (AXLE TO AXLE): 76cm (30 inch)
DECK WIDTH: 10 inches
TRUCKS: 180mm Patented Direct Drive Reverse Kingpin Scarlett Red Precision
Trucks ~1mm positive truck rake. 46 degree front and 30 degree rear
truck base-plate angles. 90A Barrel Bushings.
WHEELS: 80mm, 74a 88 Wheel Co. Maverick Pro Urethane Wheels
MOTOR: Quad 2400W-rated 5060 custom brushless sensorless motors
MOTOR CONTROLLERS/ESC: Two Dual 100A ESC’s, FOC motor commutation.
BEARINGS: ABEC 9 precision steel ball bearings
BATTERY: 40.7V, 10AH, 407Wh custom built 11S2P configuration LiPo rated for 150A maximum continuous discharge with custom BMS.
RECHARGE: 2hr
REMOTE: Patented Knuckle Duster remote with 3 torque modes
WEIGHT: 12kg
RANGE: 45km (21.7 miles)
TOP SPEED: 130km/hr (81mph)
MAX LOAD: 120kg / 265lb
SUITABLE TERRAIN: Sealed surfaces- asphalt & concrete roads
SLIDES: Yes
BRAKING: FOC regenerative braking with smooth engagement
They are claiming that the battery pack is LiPo?? Dont think this could be correct? Can someone debunk these specs or could they actually checkout and be legitmate? Or have they just put all the wrong specs on the website? Ive riden plenty of boards with more than 407Wh and they can barely reach 50-55km/h. How could this board possibly hit 130km/h?
