I've just received a BMC motor with 36v 25amp controller. Once installed, I've connected a 36v Lifepo4 battery and worked fine.
Then I've disconnected the 36v and hooked up a 48v battery - heard a sparking sound from the 48v battery (saw some smoke came out but couldn't see exactly where it came from). I've quickly disconnect and reconnected the 36v battery to see if I've damaged anything. I've some sparking sound also and disconnected from 36v battery.
I'm at a loss, now nothing will work - even my other motor/controller. When I connect the battery to a Cycle Analyst - it works fine up to that point (its a direct connect). When I connect from Cycle Analyst to a controller - I see some spark and Cycle Analyst shuts down.
Is it the battery or controller? I've checked all the connection/wire and even re-crimped a new end to make sure its not the wire.
