TristanP said:
If there's a big discrepancy between the current drawn by the controller and that applied to the motor your controller is just very inefficient.
That's just not true, at all. Controllers are PWM devices, so the input current and output current won't always match. Current drawn by the motor depends on applied voltage, BEMF, Kv, and phase current limits. The same amount of power might flow from the battery to the controller, and the controller to the motor, but that doesn't mean the current will match, nor does it mean there is any large inefficiencies.
The Adaptto controller and the Cromotor hub motor are a common combination which can, and does, pull 100A from the battery pack into the controller while the motor pulls 300A from the controller, and it's one of the best on the market.
TristanP said:
No, you don't want that. One does not choose a fuse corresponding with how much current a power source may offer. That's a ridiculously dangerous approach. Especially given the high current most power sources, including batteries, may offer. A fuse should match the circuit, being it the source circuit or the load circuit. As you mentioned a motor I assume the latter.
How is that a dangerous approach? If the controller pulls 100A from the battery, and the CPD is going between the controller and the battery. Than you want a CPD rated for that circuit. You want a CPD that allows a continuous 100A but if it goes much higher, it will trip. My question is all about how much higher, what kind of CPD, fast blow fuse, slow blow fuse, same for breakers, obviously it needs to be a DC breaker, but beyond that I am at a loss.
TristanP said:
When a pack doesn't output more then 100 amps max, you can't exceed that by drawing more current. A properly build battery pack will have a BMS, and all the decent ones offer over current protection. Typically one which doesn't exceed the capabilities of the cells.
The purpose of the CPD is if the BMS fails, or if the controller fails, or if the motor fails, to protect all the other devices in the circuit.
TristanP said:
That being said you mentioned your motor and the fuse to be used between the battery and the motor.
Actually I didn't say that. You said that. I said that the CPD will be between the battery and the controller. Controllers are PWM or VFD devices, so the voltage and current coming out of them will be different than the voltage and current going into them. Your motor can be pulling 300A from the controller, and the controller can be pulling 100A from the battery pack. So obviously, you would need to use different breakers/fuses for different points within the circuit.
