Arbol
I have seen a new (for me at least) Panasonic battery:
http://www.greenbikekit.com/index.php/36v-9ah-panasonic-lithium-ion-battery.html
Due to the discussion at:
http://endless-sphere.com/forums/viewtopic.php?f=14&t=52651
It seems the Panasonic battery seems to make sense to build a bigger battery: it is from a reputable brand, it is small, light and apparently with a high continuous discharge rate.
From the pictures, it seems the battery is to be anchored to the bike in vertical position. Supposedly, one could anchor the battery anywhere, I assume there is another piece that can be mounted anywhere in the frame that serves as a support to the battery. Also, it is not clear which is the anchorage point. It seems as if that piece of plastic in the back, with four grooves (two long, too short) should be the anchor point. But the picture says that is the discharge outlet, so I am at a loss. Also, if that were the anchorage point, it would seem more logical to put the battery in horizontal, not in vertical.
Does anybody know the answer to that question?
And in general, the 18650 Panasonic are good cells?
