CUDAcores89
1 W
- Joined
- Aug 28, 2016
- Messages
- 51
Question says it all, how do I charge a 72v battery I am building?
I am planning to build a 72v battery out of some samsung 20Q cells from power tool batteries that I got a really nice deal on locally, Only $1 per cell. Only issue now is how to charge it?
Currently I run a 52v battery with no BMS. The battery pack is actually two 7S packs electrically. I use my icharger 208B for charging up the pack after I have split it into two 7S sub-packs and discharge it by putting the packs together into a 14S battery. I use those 8S battery buzzers on the balance leads during my ride to warn me when the pack get's too low.
With 72 volts, I can't do that since that would be two 10S battery packs. I don't currently own a 10S lipo charger so that won't work.
I could also split the pack into a four 5S battery packs. But that means I will have a ton of balance leads and connectors coming out of my pack that I want to avoid.
I could also just install a single large connector and install an 8S + 6S + 6S balance leads on the pack and charge through the balance leads using my icharger and my two imax b6, but that would be very slow.
I could also just hook up a 20S BMS for charging and run the battery BMSless for discharging.
What has the community done? Charging 72v DIY ebike batteries starts to get tricky, and I would like to see what others have done.
